2005 Power Windows
2005 Power Windows
Hey Guys,
So here's the problem: I just installed the GT-V6 Grille conversion kit (my stang looks wayyy meaner now) and I thought all was fine and good. Shortly after (also the first time it rained after the installation) I noticed that the window wasn't closing all the way on the drivers side. You know how the window goes down a tiny bit when you open the door, well now it won't go up when I close it (only on the drivers side). The power window still works when I push the little lever, so I'm thinking it's some weird electrical problem or possible a fuse. I'm sure this has something to do with the recent mod, but all I did was run a completely seperate wire from the grille to the light switch. Any suggestions (other than book an appointment for warrenty and wait a million years to get in)?
Thnx.
~orion6g
Thnx.
~orion6g
RE: 2005 Power Windows
How would a grill have anything to do with a window?????Its not anything to do with that.You sound like my Grandma i changed her oil and she said since i did it her tires are losing air???I said nan its nothing to do with the oilBook an appointment cause you have an electrical problem
Maybe you need to have your f*cking eyes checked out. I said in my post that it shouldn't be because of that but I did run wires from the grille to the lightswitch and to the battery. You gotta think before you type man.
"I'm sure this has something to do with the recent mod, but all I did was run a completely seperate wire from the grille to the light switch. Any suggestions (other than book an appointment for warrenty and wait a million years to get in)?"
Not to take sides here orion6g but you did say in your first message that you thought it had something to do with your recent mod. Now you probably meant to say that it didn't have something to do with it, but I took it the same way as 99saleen351r took it.
AmericanMuscle4.6GT
11-10-2015 02:06 PM
DreadPirateRoberts
09-26-2015 02:11 PM
zanemoseley
09-06-2015 12:58 PM
