Short block dilemma...
Hey everyone, I recently got a 302 short block that I got machined and bored over .30. Ive been looking for a 331 stroker kit but all the ones ive found are too expensive. Lowest price I founnd was $1200. But I found a 347 stroker kit for $800, I heard all about the 347 being natorious for burning oil, I have the money to get the kit now but I wanna know your opinion, should I just wait to get the 331 or just go for the 347? I want it sooo bad.
Heres the link for the 347: http://coasthigh.com/Specials/Specials_current.htm
RE: Short block dilemma...
Also my next question is can I use the stock heads (polished and ported of course) running 10.0:1 compression? Also I think I may have to take the heads back to the machine shop to take them to w/61cc head and .015 deck is tht possible?
The 347 burning oil thing is long gone.I cant believe everyone still thinks that that problem was solved years ago.My friend has had a 347 for over 2 years and never burned a single drop of oil.If i was building a motor I would build the 347 or a 351 because the is no replacement for displacment
331 Stroker Kit
DSS STROKER KITS --------------------------------- 306 ROTATING KIT 306 LONG ROD ROTATING KIT 331 STROKER KIT 347 STROKER KIT 408W STROKER KIT ------------------- MODULAR ------------------- 4.6 MOD ROTATING ASSEMBLY 5.0 MOD STROKER KIT
KIT Includes:
•DSS Pro-Lite forged pistons
•Forged polished I-beam rods with 3/8" ARP bolts
•Cast steel stroker crankshaft
•Moly rings
•Tri-metal rod and main bearings.
331 Pro Series Kits
includes: DSS Pro Series Pistons, Forged I-Beam rods, cast steel stroker crankshaft, moly rings, tri-metal rod and main bearings.
331RK1000 Pro Series Pistons - Flat Top/Inline/Twisted Wedge $939.95
331RK1001 Pro Series Pistons -13cc Max Quench/Inline/Twisted Wedge $979.95
331Pro-Lite Series Kits
includes: DSS Pro-Lite Series Pistons, Forged I-Beam rods, cast steel crankshaft, moly rings, tri-metal rod and main bearings.
331RK2000 Pro-Lite Pistons -3cc Flat Top/Inline $1095.95
331RK2001 Pro-Lite Pistons -13cc Max Quench/Inline $1135.95
331RK2002 Pro-Lite Pistons -3cc Flat Top/Twisted Wedge $1115.95
331RK2003 Pro-Lite Pistons -13cc Max Quench/Twisted Wedge $1155.95
331RK2004 Pro-Lite Pistons -18cc Max Quench/Inline/Twisted Wedge $1155.95
Balance your D.S.S. Stroker Kit for an additional $175
Go check out dssracing, these are the prices for their stroker rotating assembly, their kits start at $939. If you are going to just run all motor, Iwould recommend the 347 because they are torque monsters, but the specs for the 331 are very similar. I would recommend the 331 if you are going to supercharge or turbo the car.
KIT Includes:
•Moly rings
331 Pro Series Kits
DSS is the worst place to buy a motor.....347 anyway you go!Why not just get a 351 you have allot more option and its cheaper than building a stroker motor and more reliable.Not that the strokers aren't but there is no machining to the block necessary and a stock 351 block can handle allot more Hp
Matt's 95 Stang
10-05-2015 07:16 AM
