Need tranny advice for 500 + hp
My ride is presently rated at about 425 hp at the crank and is NA. I am planning on adding a blower next summer and figure I will have to put a tranny in as well since I presently am still using the stock one which I am told won't handle much more power. Any recommendations on what I should go with. I am thinkng 6 spd but that is not really a must. Any thoughts / advice would be much appreciated.
RE: Need tranny advice for 500 + hp
So I will be looking at around 1700 for a new Tremec TKO600 5 spd. Does that sound about right? The 6 speed is a little more. What do you guys think I should go for? I am leaning toward the 6 speed even though it will probably be 700 more. Then KB here I come.
Six speeds are nice because you have the double overdrive but the tko tranny is nice also they both will handle that HP.The T56 might be a little more work to insatll then the TKO cause I'm not sure the crossmember will work
treesloth
09-28-2015 07:03 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
