Sponsored by:
Sponsored by: DashLynx
What's traction loc? Does my 01 GT has posi?
Old 08-05-2005, 09:49 PM
4600cc
I ♥ Acer
4600cc's Avatar
Default What's traction loc? Does my 01 GT has posi?
What is traction loc and how is it different from lsd? Does my 2001 GT has lsd or an open rear end? What gears does it have?
AL
4600cc is offline
Old 08-05-2005, 10:19 PM
Chopper
Chopper's Avatar
Default RE: What's traction loc? Does my 01 GT has posi?
You have a limited slip rear end with 3.27 gears.If you only get one black mark when you burnout,the clutch pack needs replaced.
Chopper is offline
Old 08-05-2005, 10:29 PM
4600cc
I ♥ Acer
4600cc's Avatar
Hehe. You can say that again, I love hearing that! I get two nice black tire marks when taking off from toll plazas. 16k miles, mint car, nothing needs to be replaced.
What's traction lock? I read traction lock in user's manual, then I heard something about traction lock. Is that the same as LSD? I know, "SRS... wtf? a limited edition???", I'm a bit out dated with the technology here. I used to have everything basic, didn't even have ABS or variable steering on my last car.
4600cc is offline
Old 08-05-2005, 10:51 PM
Chopper
Chopper's Avatar
I think that is just another name for"limited slip".If you look under limited slip in the owners manual it says to look under traction lock.Why they would do this is a mystery.HMMMM
Chopper is offline
Old 08-05-2005, 11:57 PM
razarr69
razarr69's Avatar
I believe traction lok is Fords version of a somewhat posi but its more a limited slip. I think all stangs come with this. not sure on that one tho.
razarr69 is offline
Old 08-06-2005, 12:01 AM
4600cc
I ♥ Acer
4600cc's Avatar
ORIGINAL: razarr69
Yea, I heard something like that. My stang went sideways today with traction control on, in the wet, in 2nd. It felt real nice, manageable. So whatever is there is pretty good, I just want to find out what is traction lok and if it's a posi, so that I drive it accordingly.
AL
4600cc is offline
Old 08-06-2005, 11:37 PM
Blue Oval
Blue Oval's Avatar
im not 100% sure, but traction lok will spin both tires equally when going straight, but if your turning, just one wheel spins. i think its something like if the difference between the wheels spinning is 100 or more RPMs. getting that 1 wheel to spin when turning at a stop sign can be really easy, ill spin it and be like wtf i didnt even give it that much gas!
Blue Oval is offline
Old 08-06-2005, 11:41 PM
redass02gt
EXTREME Moderation
redass02gt's Avatar
your 01 has traction lock. this is ford's posi. same thing, different brand. I think all 99-04 GT's came with traction-lok.
redass02gt is offline
Old 08-07-2005, 01:06 AM
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
all Mustang V8's came with trac locs since 1986 or 87
mdvaldosta is offline
Old 08-07-2005, 01:08 PM
GreyStang
GreyStang's Avatar
You can easily tell if you have LSD/posi/whatever..
Raise the rear wheels off the ground and spin one wheel by hand. If the opposite wheel spins in the same direction you have posi.
How can you tell if your posi clutch is worn out? Have a buddy hold onto one wheel while you try & turn the other by hand. If you CAN'T spin the wheel by hand your diff clutches are probably fine.
GreyStang is offline
Quick Reply: What's traction loc? Does my 01 GT has posi?
