71 MACH 1 NO GAS TO CARB
Hello, I am working on my FNL's 71 mach 1 351 C 4v Ram Air car and I'm not getting fuel to the carb. Let me set things up.
The car had been sitting for a few years after I got it running and the gas went bad. We rebuilt the carb but I had to empty the tank so I let the motor do the work. I hooked up an old fuel line and turned the motor over until no more fuel came out. I put in new fuel, hooked it back up and now no fuel. I pulled the line from the carb and tried and nothing. What gives.
I know nothing about a Ford what so ever so all the help will be appreciated. I'm not sure where the fuel pump is located on this engine, is the fuel filter only located next to the carb? This car is all original nothing has been modified.
The car only has 53,000 miles on it and when it run's it RUN's.
Mechanical on the side of the front timing cover. Probably needs to be primed, ie you need fuel in the line from the pump to the tank to get the pump to start pulling fuel. The filter should be somewhere between the pump and carb.
breaking
10-02-2015 01:27 PM
