fog lights
fog lights
I did this mod a few years back with a 91 GT, what I had to do was pull the switch out and cut a wire that powered the fog lights and tied it to the wire powering the parking lights. I never had any problem with overloading circuits. I can't remember what color the wires were but if you take a multimeter you should be able to figure it out fairly easily!! hope this helped some. The mod only takes a few minutes but its worth it. The look is cool!
fog lights
Keep in mind the 95 cobra is a little different, but the concept is the same on the SN95 you also can do the work from the switch, basically on the 95 cobra you can take the wire harness apart and change two wires. Don't let anyone tell you this is a bad idea bacause of the current draw. The switch just supplies power to a relay that is under the dash!!!
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
