flywheel vs total hp
Guest
Posts: n/a
RE: flywheel vs total hp
thank you si the information was very helpful and also one last question i knew fwd handled better but if a fwd puts down more power to the wheels because of a lot less drivetrain loss why is it believed rwd is better for performance shouldnt fwd be faster
ORIGINAL: redass02gt
when you accelerate, the weight of the car shifts to the rear wheels (not all, but a significant amount). rwd cars get better traction on their drive wheels when they accelerate. that's why badass cars can do a wheelie.
also, fwd will put more power to the tires, but not to the ground. small difference in words, big difference in reality.
Now see I have a problem with the last sentence. If the power is getting to the tires, it's getting to the ground. Sure every piece of the drivetrain takes a certain percentage... but the power that makes it to the tires vs the power that makes it to the ground is going to be so insignificant that comments like this are unnecessary.
If you have a FWD vehicle and a RWD vehicle making Identical horsepower numbers at the crank, the FWD vehicle will always out dyno it.
depending on the car...your hp to the wheels will be about 15-20% less than the flywheel hp. Automatics will suffer more driveline loss than manual tranny cars.
For example is is estimated that the there is a 15% driveline loss in the '05 manual transmission gt's (autos are around 20%). So if you dyno at 260 hp at the rear wheels, your hp at the crank (flywheel) will be 260/0.85 = 305.88 hp
Another thing to even confuse you more...Mustang or Load Dynos generally get lower numbers than a DynoJet or Chassis dyno. They estimate 8-10% higher numbers on a dynojet. If you look around on websites that sell performance products, they usually will give you dynojet numbers because they are higher.
what I meant was that the fwd will not get traction as well as the rwd, therefore not putting the power to the ground as well. You can put 1000hp to the wheels, but it won't get to the ground as well in fwd as it will with rwd. all other things being equal.
blackout -
the rwd vehicle will get better traction off the line and it will be less likely to have a poor launch. during any acceleration, the weight shifts to the back. a fwd car would have be ridiculous to drive on a street if it had a suspesion setup severe enough that it would get similar traction to a rwd car.
Guest
Posts: n/a
ORIGINAL: blackout
Wait so how can an auto rwd car beat an auto fwd car if they have the same hp rating at the flywheel
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
mrappe
09-26-2015 10:16 AM
