Sponsored by:
Sponsored by: DashLynx
High Idle
Old 08-15-2005, 01:48 AM
Zincpony
Zincpony's Avatar
Default High Idle
when i first turn the car on. it idles at around 1300RPMs. i have to rev the engine a few time to get it to go below 1000RPMs. why is that all the sudden
Zincpony is offline
Old 08-17-2005, 03:40 AM
Dangerfield23
Dangerfield23's Avatar
Default RE: High Idle
Have you tried cleaning the IAC valve?
Dangerfield23 is offline
Old 08-19-2005, 10:54 PM
88GT40
88GT40's Avatar
it not wrong for that to happen it's like a choke but the computer regulates it, in conjuction with the iac vale and tps sensor, you should not rev the engine until it has had a few minutes to get a little warmed up and you shouldn't drive it hard until your into the normal range.
88GT40 is offline
Old 08-19-2005, 11:56 PM
razarr69
razarr69's Avatar
yeah man that is what its suppose to least i think so, mine does it fer a few minutes depending on tha temp outside, it does it at about 1100 then drops to bout 800 er so then i take it easy fer tha first couple of km to let it get warmed up.
razarr69 is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
69Volunteer
09-30-2015 10:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: High Idle
