Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-17-2005, 06:07 PM   #1
Dan04COBRA
Super Moderator
Send a message via AIM to Dan04COBRA
Default Gen. TECH: Seasonal Storing of your Mustang help/tips
Storing your car for the winter? Going on a long vacation?
Post all your tips, information & questions here!
__________________
Black 04 Cobra For Sale. Click Below
http://mustangforums.com/forum/musta...216-black.html
Dan04COBRA is offline   Reply With Quote
Old 08-17-2005, 06:14 PM   #2
sowaxeman
Moderator
sowaxeman's Avatar
Vehicle: 82 GT / 85 GT 'vert / 05 S-281
Default RE: Gen. TECH: Seasonal Storing of your Mustang help/tips
I NEED a tip! Can somebody tell me the life of synthetic oil vs regular?? I put 1000 miles on my car this year, and probably won't do much more than 1500 total. I put synth in it at 500 miles per the Saleen Manual. Before I "store" it this winter is it best to change it again, or leave it and change it in the spring, or just leave it altogether until I reach 3000 miles??
__________________
Jason Smith
Saleen Club Of America - Central Region Director
http://www.saleenclubofamerica.com/Central
1982 GT : 1985 GT 'Vert : 2005 S-281 #92
*Due to Notification issues, I may not receive PM's in a timely fashion. Please send me an email if you wish to contact me directly.
sowaxeman is offline   Reply With Quote
Old 08-25-2005, 12:10 PM   #3
firestarter
damn , and i was wondering why mustangs get stored for winters , im getting one in the next couple of weeks , and i wanted to know , 'is it impossible to drive it while raining?'
firestarter is offline   Reply With Quote
Old 08-25-2005, 02:39 PM   #4
ShadowDrake
Send a message via AIM to ShadowDrake
Quote:
ORIGINAL: firestarter
I haven't had too much of a problem in the rain, but with the stock tires, you definitely lose a LOT of traction on wet roads... I really couldn't imagine it on an icy road.
__________________
2004 Black Premium GT (5spd)
-Procharger P-1SC intercooled
-Moates.net Quarterhorse
-Tuned with Binary Editor
MY PICTURE THREAD:
http://www.mustangforums.com/forum/s...d.php?t=497078
ShadowDrake is offline   Reply With Quote
Old 08-25-2005, 06:04 PM   #5
FWP!
Send a message via AIM to FWP!
Quote:
ORIGINAL: sowaxeman
You shouldn't leave oil in your crank case for more than 3-4 months. Even if you only put 1000 miles on the oil. Especially over winter. But, if you plan to park it until spring, don't worry about it but do put fresh oil in it before you start it in the spring. If you DO plan to run the car over winter and you're in a colder climate, change the oil. Starting your engine and warming it up to 220+ degrees from 30 causes a lot of condensation which the oil absorbs and turns into different types of acids, actually corroding your engine from the inside even faster than it does normally in warm weather. H2o production is a normal part of the engine's combustion process and most of it is burned off through the PCV system which also scavenges other gasses from the crank case, but not all of it is illiminated.
In short, if you plan to park your car all winter and never run it, don't worry about the oil change till spring. If you plan on driving it a few times, change the oil and change it again at some point during the winter if you want to take excellent care of the engine.
__________________
New '00 GT owner... Magnaflow cat-back, leather, 5 speed
FWP! is offline   Reply With Quote
Old 09-06-2005, 07:35 PM   #6
pgervais
Between high gas prices and Icey/Snow covered roads (during the winter) I have decided to store my Cobra for the winter.
Any suggestions on how to keep the battery from being drained?
The car will be stored in a heated garage but i do not feel like jumping it when I am ready to roll in the spring.
__________________
Pat Gervais
'01 Cobra Convertable
Lazer Red
pgervais is offline   Reply With Quote
Old 09-07-2005, 06:10 PM   #7
sowaxeman
Moderator
sowaxeman's Avatar
Put a trickle charger on it once a month for a day (or however long it takes the charger to tell you it is charged). To avoid flat spots on tires and other "storage" issues, you're best bet would be to get it out once a month on a dry sunny day and take a short jaunt in it to get everything flowing and moving. If you do this it will most likely keep you from having to trickle charge the battery.
__________________
Jason Smith
Old 09-27-2005, 05:20 AM   #8
AmericanMuscle
Quote:
ORIGINAL: sowaxeman
Here's my situation: I will most likely have to move my car out of my garage to do some work (manafacture in my garage) maybe as much as every other day or every third day. I just have to back it into my drive way so I don't scratch the **** out of it with sheets of fiber glass + metal bars. So should I do anything special? Should I let it run for 5-10 minutes or longer on days that I have to move it? I plan on getting a cover for it while it sits idle... and what about the oil? Since it's getting moved should I leave it till spring? I'm at 200 miles right now, haven't even had my first oil change.
__________________
"why do you GT guys always say get a GT, if you really think that then you should go get a Cobra. damn" ~matthockey32
AmericanMuscle is offline   Reply With Quote
Old 10-23-2005, 01:56 AM   #9
72MachOne99GT
1999 Ford Mustang
72MachOne99GT's Avatar
Vehicle: 1999 Ford Mustang GT
Send a message via AIM to 72MachOne99GT Send a message via Yahoo to 72MachOne99GT
i put my car in a 'carbag' (actually called that) and so does my dad with his 72
we roll the windows down a crack, get the car in position, pull the battery and store them in the warm building(no, the cars dont fit[:@])
we just change the oil first thign in the spring
im wondering about psi in the tires for this winter
any help?
__________________
'99 GT-5sp.
4.10's, O/R H, catback, MT's
13.6@100 1.8 60'
72MachOne99GT is offline   Reply With Quote
Old 10-25-2005, 09:17 AM   #10
HC_CrAzYHoRsE
Super Moderator
HC_CrAzYHoRsE's Avatar
Vehicle: 1990 notch
i put extra coolant in it, then i go and start it evey 2-3 weeks for about 20 mins, while it's running i push on the front end and then the rear end for about a minute each, just so the suspension moves a bit, then i roll about 1/2 a foot forward to avoid bald spots in the tires. that's it ...worked pretty well till now. i have the oil and filter changed when i take it out.
__________________
Religion is the problem
My Site
HC_CrAzYHoRsE is offline   Reply With Quote
1982, 2000, 2005, car, draining, gas, gt, mustang, oil, run, saleen, stored, storing, synthetic, tips, weather, wet, winter
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
