Gen. TECH: Manual transmissions, T5, T45, 3650, T56 ETC..... - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 04-28-2006, 03:33 PM   #21
97targa
Default RE: Gen. TECH: Manual transmissions, T5, T45, 3650, T56 ETC.....
Tranny's hold up to pretty much anything, Just depends how you run them. We all know if you got the power use it! This restricts tranny life. I had a 6-speed in my 91 w/347 stroker trick flow heads, and Paxton S/C 12psi and ran high 11.00's on street tires. CENTERFORCE DUAL FRICTION. AWESOME!! So smooth. I re-calibrated the transmission with different gears and worked with the rear to achieve a top speed of 145mph in sixth gear. This was plenty of top speed and it gave me the flexiblity to use sixth gear on the highway @65mph and still have enough nut to pass a car without downshifting. I seriously reccomend having stuff like this done by proffessionals, because it took me a while to put the set-up together. 3 tries to be specific. Either 2nd was too close to 3rd or 5th was to far from 6, then 1st was too freakin low to even bother, I could have towed a house with first. Althoug it was fun when I put on slicks, I was poppin 3 foot wheelies with 1/2 throttle. But it worked it the end. By the way I ran 10.06@123mph in 4th gear never let off the gas since may car could handle 8,000 rpm power maxed at 7100rpm
97targa is offline   Reply With Quote
Old 05-05-2006, 12:09 AM   #22
jaypatterson99
does anyone know how to get the manual gear driven speed o t 45 to work in a newer model t 45 that has a digital speed o.
is this a simple fix . my cobra has a digital and the t 45 i bought has a manual speed control.
jaypatterson99 is offline   Reply With Quote
Old 05-12-2006, 05:39 PM   #23
5.Joe
I have a t-56 in my 91 Gt. It came with 3:55 gears and i swapped them for 4:10's and that trans and gear combo rocks! I still have plenty of top end and major power through 4th gear. Every shift the car is in the powerband. Only problem is at the track i run nitrous and i cant hook even with mickey et's through the 8th mile.
5.Joe is offline   Reply With Quote
Old 05-19-2006, 02:19 PM   #24
wedgieman
How do I adjust the shift stop on a 1986 5 speed
wedgieman is offline   Reply With Quote
Old 05-19-2006, 07:20 PM   #25
86droptop
i did the aod to t-5 swapto my 86gt but on the wire harness all i could get from donor car (89gt) was the three plugs under car and about 1 1/2 ft of slack so i have no end to plug into main harness where my aod one was any idea how to work this out i need backup lights and neutral start and my speedodmeter ???????//
86droptop is offline   Reply With Quote
Old 06-04-2006, 12:05 AM   #26
teh rabbit
I have a '99 v6 and I am going to replace the tranny. I am considering going with t45...how much modification, if any, is required to do this swap??
...my stock tranny is a t5
teh rabbit is offline   Reply With Quote
Old 07-02-2006, 10:13 PM   #27
Gar4pt6
what kind of fluid are you guys putting in the 3650?
Thanks
Garrett
Gar4pt6 is offline   Reply With Quote
Old 07-04-2006, 12:44 PM   #28
99sbm
99sbm's Avatar
97targa:
do you mind telling what ratio's you used, and where you got your gears from?
99sbm is offline   Reply With Quote
Old 07-04-2006, 09:01 PM   #29
frost1357
i have 92 5.0 will a tremec t45 from a 98 gt fit
frost1357 is offline   Reply With Quote
Old 07-23-2006, 12:24 PM   #30
roadkill
i believe a t56 has closer ratio's, but yes my 6th gear is pretty useless to me considering the highest speed limit around me is 50mph :-/ i need to be going atlest 60 but i like to hold off to 65-70mph anyways, cant beat it if im traveling tho, it sits around 2100-2200rpm @ 80mph and my mpg's are between 26-28 in 6th at those speeds. i drive a camaro btw w/ 3.73's
but if you've got a t56 and ever need work done i highly suggest these guys www.t56rebuilds.com first i looked around locally for a good tranny shop, some didnt want to touch it at all and just wanted me to drop $3200 for a new tranny.. other shops told me incorrect stuff like i dont have a reverse synchro lol so i took it out myself and got it rebuilt and built up for $1600(reverse, 1-2, 3-4 & 5-6 sliders, billit keys, steel 3-4 fork, bronze 1-2 &3-4 fork pads, carbon fiber synchro rings, plus i needed new reverse, 2nd & 6th gears other than that it would of been $1200 all together)
roadkill is offline   Reply With Quote
T3650 to T45 Swap MichelleBeMyGT 4.6L (1996-2004 Modular) Mustang 16 03-15-2010 06:48 PM
best rear end and transmission combo? silverblue66 Classic Mustangs (Tech) 0 10-05-2006 05:21 PM
2003-2004 Cobra GT03 4.6L (1996-2004 Modular) Mustang 13 09-09-2004 02:46 AM
Tranny Conversion Big5.0.13.7sec. 5.0L (1979-1995) Mustang 7 07-28-2004 08:29 AM
t45 t56 67 coupe cobra427302 Classic Mustangs (Tech) 4 06-18-2004 05:43 AM
01, 3650, bad, body, converting, fit, fox, gear, manual, mustang, neutral, noise, older, t45, t5, t56, tech, transmissions, work
