Gen. TECH: Manual transmissions, T5, T45, 3650, T56 ETC..... - Page 7 - MustangForums.com
Sponsored by:
Sponsored by:
Old 12-03-2012, 07:54 AM   #61
95mercxr7
i know the t-56 and the t-45 will bolt up to the same bell housings i got the t-56 just to have the 6th gear. my neighbor baught my t-45 off of me i said this is the miles on it this is the service record you know changing the fluid to straight synthetic he knew i rarely drove it do to every one in my area didnt know how to drive. it only had 36,500 on it. he gave me the price of the rebuild on minuse the shipping. i do love the added gear to help with the distance drive.
95mercxr7 is offline   Reply With Quote
Old 12-14-2012, 05:23 AM   #62
98SVT4V
Quote:
Originally Posted by Barbdwire21 View Post
my T45 in my mustang GT is making chattering noises sometimes in neutral and is hard to get it in all gears i had a new clutch put in it recently and ive heard the quadrents go bad in these things leave me a message if you have any ideas about this
Hey Barbdwire,
What kind of clutch did you have put in? If it's stage II or above, it's most likely made out of Kevlar and is going to take some time to break in. I had a Spec stage II clutch installed, and now after about 1,000 miles of easy driving around town, the chatter is smoothing out. I also spent an additional two c-notes and bought an aftermarket quadrant with a cable adjuster that mounts on the firewall. Best two hundred bucks I ever spent!
98SVT4V is offline   Reply With Quote
Old 08-30-2014, 07:38 PM   #63
bart327
Default wipers
I have a 1990 mustang 5.0 and the wipers turn on automaticlly with the switch off. any help would be helpful.
bart327 is offline   Reply With Quote
Old 09-02-2014, 10:49 AM   #64
88 orangepeel notch
88 orangepeel notch's Avatar
Welcome to the forum Bart, but your should start a new thread in the appropriate tech forum. This thread is dedicated to trannys. We'll help you get it figured out .
88 orangepeel notch is offline   Reply With Quote
Old 09-02-2014, 01:36 PM   #65
KTownDaddy9
Default TREMEC TR-6060 6 - Speed Manual Transmission
Can anyone tell me if they have used one of these trannys TREMEC TR-6060 6 - Speed Manual Transmission on a 1995 Roller Block will they mount up ? and if special adapters are needed
KTownDaddy9 is offline   Reply With Quote
Old 09-02-2014, 03:10 PM   #66
dawson1112
Quote:
EWWW!!! lmao
dawson1112 is online now   Reply With Quote
T3650 to T45 Swap MichelleBeMyGT 4.6L (1996-2004 Modular) Mustang 16 03-15-2010 05:48 PM
best rear end and transmission combo? silverblue66 Classic Mustangs (Tech) 0 10-05-2006 04:21 PM
2003-2004 Cobra GT03 4.6L (1996-2004 Modular) Mustang 13 09-09-2004 01:46 AM
Tranny Conversion Big5.0.13.7sec. 5.0L (1979-1995) Mustang 7 07-28-2004 07:29 AM
t45 t56 67 coupe cobra427302 Classic Mustangs (Tech) 4 06-18-2004 04:43 AM
01, 3650, bad, body, converting, fit, fox, gear, manual, mustang, neutral, noise, older, t45, t5, t56, tech, transmissions, work
