Help diagnose my problem - MustangForums.com
Sponsored by:
Sponsored by:
Old 11-17-2010, 12:55 PM   #1
Alec
Alec's Avatar
Default Help diagnose my problem
Probably gonna have to have a shop look at it but I figured you guys might know.
This past weekend a few of my friends and I started to install my 8.8 rear but didn't get far due to time and daylight constraints. Had to put the brakes, speed sensor, swaybar back on and rebolt up the shocks.
A few hours later, I was driving and heard something sound like it was grinding. I at first thought the swaybar got loose and was dragging but that wasn't the case. Looked over everything we took off and couldn't find anything.
Now the OD light is flashing, shifts are rough and first grinds. We didn't touch the trans, so it would be one hell of a coincidence for the trans to go right after. The car is driveable but doesn't sound good
Anyone have any thoughts?
Alec is offline   Reply With Quote
Old 11-17-2010, 02:57 PM   #2
gconnsr
No telling Alec, but is it possible the rear brakes are dragging? P.S. Nice job on the body mods bro.
gconnsr is offline   Reply With Quote
Old 11-17-2010, 03:00 PM   #3
Alec
Alec's Avatar
Quote:
Yeah wasn't sure if there was any telling signs. That's one of the first things I checked, took off the calipers and rotors and found nothing odd. I'm taking the car to have it looked at Friday and am hoping for the best
Thanks! It's come a loong way from the base 4.0 look
Old 11-17-2010, 03:18 PM   #4
gconnsr
Good luck to you man, hope it's something simple. Wouldn't mind hearing a sound clip of that six with duals.
Old 11-17-2010, 03:18 PM   #5
Derf00
so you did or did not do the 8.8 swap? I'm thinking something is misaligned on the output shaft to differential (drive shaft) and its putting a strain on the gears (grinding) that misalignment is also now putting a strain on the tranny (output shaft) and why the it doesn't want to shift right.
Derf00 is offline   Reply With Quote
Old 11-17-2010, 03:21 PM   #6
Alec
Alec's Avatar
Thanks I really appreciate it. It's gonna be something simple, like a speed sensor, or a trans problem which will ruin my day
I'll take one when I have the time and camera and post it. I think it sounds pretty good for a 6, but is no V8 even though a few people ask if it is.
Old 11-17-2010, 03:25 PM   #7
gconnsr
Cool. My son did a Flowmaster 40 on his single exhaust 4.0 and I didn't like it. I'm thinking your dual setup would sound much better.
Old 11-17-2010, 03:37 PM   #8
a_penquin
a_penquin's Avatar
jack the back end up, put it in neutral, and spin the rear. Listen for anything that could drag, and pay attention to the diff itself. Did you pop the cover on the 8.8 and check the gears before installing??? Also do some measurements between the axles, the 8.8 may have a longer snout. Thats just some immediate thoughts for now.
I would put it down to a length difference, damaged gear, ABS sensor/wheel damaged, or possible pinion angle.
a_penquin is offline   Reply With Quote
Old 11-17-2010, 05:26 PM   #9
Alec
Alec's Avatar
Quote:
No, that's the thing I don't understand, we didn't even really get to tear into anything really besides the brakes and some suspension so I don't know how I'm having such an issue. Of course it could be a major coincidence ...
Flowmaster 40s sound awesome on the 3.8 New Edge 6's (heard em in person), but apparently are horrible on the 4.0s. Seems like it's a tough engine to get the right sounding exhaust note out of.
One thing I noticed, is that I hear a rattle when I rev it a little in park and neutral. Don't like the sound of that, literally
One of my more mechanically advanced friends looked over the 8.8 and put a new gasket on and sealed it up. Said it looked good. Didn't even get it installed in time though
Old 11-17-2010, 05:34 PM   #10
a_penquin
a_penquin's Avatar
I would check lengths, I have a feeling there may have been a slight difference causing the yoke to do some damage to the trans.
Otherwise I would mark it as a fluke....
Loud Noise Above 30 MPH bjdutch2005 2005-2014 Mustangs 10 03-24-2017 03:38 AM
High Pitch Whine. Help? FivePointToTheOh 2005-2014 Mustangs 9 09-29-2015 12:53 PM
HELP! Dead Battery After Tire Change?!! jessicarabbit GT S197 General Discussion 12 09-25-2015 12:41 PM
1996 GT Studdering problems.. Need Help stangin1996gt 4.6L (1996-2004 Modular) Mustang 0 09-21-2015 11:01 AM
AODE Woes Pyrate Dave 5.0L (1979-1995) Mustang 8 09-10-2015 07:30 PM
