Sponsored by:
Sponsored by: DashLynx
Mass Air Flow Sensor/Fuel Pressure Problems
Old 08-18-2005, 09:55 PM
p0rsche23
p0rsche23's Avatar
Default Mass Air Flow Sensor/Fuel Pressure Problems
I need some help with my 98 v6 mustang, when i had the computer checked because of check engine problem the first thing it said was the o2 sensor behind the catalytic converter, but after replacing that it came with 2 different bank codes (P0171)which stated that the computer recognized too rich or too lean condition on one engine bank only,(too lean), and said to suspect fuel pressure or the Mass air flow sensor....or that was the first choice anyway, and this part is around 100 which i have a buddy who sells mustang parts off wrecked stangs so about half of that but i still dont want to spend that much on the sensor if it is something totally different...i recently replaced the fuel pump about 3 weeks prior to this and after this occurred i check the fuel filter and it was fine so i dont know what else it could be........ummm it sounds like a go cart taking off puttering and such and has about as much acceleration as one too.....it runs to about 60mph at its peak and then inconsistently the fuel pressure or rpms will fade where it cant even be revved past 2 rpms........any help would be needed in diagnosing this problem.....thanks
p0rsche23 is offline
Old 08-18-2005, 11:05 PM
4600cc
I ♥ Acer
4600cc's Avatar
Default RE: Mass Air Flow Sensor/Fuel Pressure Problems
Yes! It is your MAF. I gurantee it. Don't drive it until you get it fixed, learn to ride bus.
What you can do is clean the MAF sensor and see if it helps.
If you are going to get a new or used MAF be sure it is from the same model year and has the same P/N. Your computer is calibrated to a specific MAF function, if you get a different MAF a different calibration will have to be done to your computer, expensive.
Here is what a MAF transfer function looks like.
Code:
 MAF Voltage / Flow kg/hr
 0   10.75
 0   10.75
 0   10.75
 0   10.75
 0.571044921875   10.75
 0.75   14.75
 0.884033203125   18.75
 1.091064453125   25.75
 1.181884765625   29.00
 1.321044921875   35.25
 1.468017578125   42.75
 1.573974609375   49.25
 1.69091796875   57.50
 1.802978515625   65.00
 1.889892578125   71.25
 1.989013671875   79.00
 2.154052734375   94.75
 2.31591796875   112.25
 2.449951171875   127.25
 2.58203125   144.00
 2.694091796875   159.25
 2.909912109375   192.00
 3.14892578125   233.25
 3.35498046875   274.25
 3.5439453125   315.00
 3.885986328125   394.25
 4.177001953125   470.25
 4.443115234375   548.75
 4.76806640625   659.25
 15.999755859375   659.25
It's a look up table for converting reference voltage to the flow. IMO it isn't very accurate, I prefer manifold pressure instead.
AL
4600cc is offline
Old 08-19-2005, 07:32 PM
p0rsche23
p0rsche23's Avatar
*%^&%R^#$ yea i cleaned the sensor wire with alcohol even tho it looked clean and yea it didnt help as i guessed and was alright to begin with......is there any way of telling by lookin at the actual MAF that it is actually the problem? i mean if im goin to spend around 100 i might as well jus save up a couple hundred more or so and jus get CAI or new air filter .......any help would be appreciated..thanks
Old 08-20-2005, 02:03 AM
p0rsche23
p0rsche23's Avatar
you guys got nothin? any help appreciated
Old 08-21-2005, 07:50 AM
mitchelguitar
mitchelguitar's Avatar
Had a Mass Air sensor go bad on me in a different car. I had the same symptoms you are describing. It turn out that there are fine wires inside the Mass Air sensor that vibrate when the air goes by them. No way to rebuild. If money is an issue I would try swapping one with someone who has a good one. Drive it and you will see the difference right away. Hope this helps.
mitchelguitar is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
67LimeCoupe
11-25-2015 08:55 PM
MXBT187
08-20-2015 02:36 AM
dfw692
08-07-2015 11:53 PM
Quick Reply: Mass Air Flow Sensor/Fuel Pressure Problems
