Go Back   MustangForums.com > Ford Mustang Tech > General Tech
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-07-2006, 07:49 PM   #51
Pete R
Default RE: Gen. TECH: Oil Filters! What to buy?
You might consider that most of the filters out there, are designed to meet the minimum spec at the lowest cost for the manufacturer. Most of the filters out there, do not filter the smallest metal particles. These would be particles under 50microns.
A good way to keep your oil clean, from those hard metal particles, is to use magnets. The magnetic drain plug is not even a half hearted attempt. Try one of the in-line filters that Ford has for auto trans. part # XC3Z-7B155-BA for trans and power steering. For engine oil, you might check Emerging Enterprises or Boss Products for a spin on adapter.
The ones that stick to the outside of filters are not as effective, becasue the oil is not in contact with the magnet. Make sure you get magnetic fitlers that put the oil right on the magnet.
I have been using these filters for years, and have been able to extend my drain interval.
Later.
Pete R is offline   Reply With Quote
Old 11-10-2006, 02:17 PM   #52
cesar5571
Vehicle: 2003 Ford Mustang Mach 1
I used to use FRAM, but switched to K&N when I bought my Mach1. No more cheap stuff, even for my other cars. Even my wife's Sonata deserves some respect.
__________________
Mods: Steeda Tri-Ax Shifter w/ 2005 Mustang GT Knob, CDC Hood Pin Kit, 25mm wheel spacers, JLT RAI, Visus Louvers.
Future Mods: x-pipe, head porting, TBA...
cesar5571 is offline   Reply With Quote
Old 11-12-2006, 09:48 AM   #53
bullitt15
Vehicle: 2001 Bullitt mustang
i bought a motorcraft filter from murrays a while ago. the kid who got me the filter mumbled ...cheap... i wanted to kick his ass. its great how these punks think theyre mechanics cause they work at auto stores. its always fun talking to the guys at the back desk, i always embarass them
__________________
Bullitt #15
13.620@102.9 2.065 60' best n/a time
103.9 best trap speed n/a
vortech non intercooled and some sweet stuff, lost the dyno sheet :O 370ish whp 370ish wtq
13.134@110.31 spinning
70mm turbo in the near future
bullitt15 is offline   Reply With Quote
Old 11-12-2006, 05:43 PM   #54
st5150
Those "crap" Fram oil filters and Walmart Tech 2000 brand oil got me 250,000 miles on my old mustang. So do you guys think if I was smart and listened to Jglisson suggestions, I would have gotten 500,000 miles ?
st5150 is offline   Reply With Quote
Old 11-19-2006, 09:32 PM   #55
harry444
Not to doubt you sources but A.C. Delco are made by general motors I have been in the plant that makes them. They are made in the Flint Mish. plant they also make spark plugs there. It was very interesting watching the oil filters being made they even have a little paint booth that they run the filters thru. It was also interesting to watch the filter medium being folded and stuffed into the filter. What amazed me was only 1 person runs the whole show its totally robotics
harry444 is offline   Reply With Quote
Old 11-19-2006, 10:38 PM   #56
PONY GUY
At work we use fleetguar don all our busses and crownvics most fo rthe busses have 300k onthem and most of the vice have 200k and all are on original motors and still are in A+ shape. For a Fleet vehical to have 300k on a factory equiped motors says alot.
On my stang i use k&n or purlator w/ 20w50 in summer 10w40 in winter
work truck fleetguard w/ 10w40
wifes car gets purlator and mobile1 oil
__________________
357W
http://www.cardomain.com/ride/2471910
PONY GUY is offline   Reply With Quote
Old 11-21-2006, 09:50 PM   #57
poopsidoo
What would you suggest for me? I have used Mobil 1 synthetic oil and filters in the past, but stopped because of the cost. See, I travel about 4,300 miules/month, so change my oil about once every 3 week. Therefore spending extra money on a top of the line filter or expensive oil seems silly....
__________________
07 Black GT Premium
poopsidoo is offline   Reply With Quote
Old 11-21-2006, 10:03 PM   #58
PONY GUY
If your using mobil 1 now i would got back to regualr oil it will messup your motor for what ihave been told just stick with what u have now
__________________
357W
Old 11-28-2006, 12:25 AM   #59
poopsidoo
No--that was in previous cars. I just bought a new 07 GT today.
__________________
07 Black GT Premium
Old 11-30-2006, 07:52 PM   #60
Pete R
poopsidoo,
In your new vehicle, you might want to start out right, and add extra filter protection. The benefits are longer life of your powertrain, lower cost of ownership, greater operational reliability.
Using good quality oil, like Mobil 1 and filters is the first step. Adding magnetic filtration is the step most forget. This will reduce friction, taking away some of that power robbing friction and improving performance.
Keeping the hard metal particles out of your oil, will allow you to keep it in your engine longer. You could easily get 10,000 miles between oil changes, if the oil is kept clean. Magnetic filtration is the only way to ensure that the most damaging particles in your oil do not continue to circulate.
If you haven't thought of it before, add in-line filters to your power steering, and if you have an automatic trans, add one to that as well. The easiest to install is the spin on that goes onto your engine. This will not void your warranty, and will add years of reliability to your powertrain (engine, trans and powersteering systems).
With the addition of magnetic filters, you can extend your oil drain intervals, and save a few dollars on oil changes.
Check the link, on the right side of the Forum, to Boss Products, they offer filters for your vehicle. The bottom line is, you are better off with magnetic filtration than you are without it.
Many happy miles with your new 07.
amsoil, bosch, buy, filter, filters, fram, kn, mobile, oil, online, review, reviews, super, tech, wix
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
