Sponsored by:
Sponsored by: DashLynx
Stock Ignition Coil/MSD coil differences
Old 08-01-2011, 10:44 AM
cpwanner103@gmail.com
cpwanner103@gmail.com's Avatar
Default Stock Ignition Coil/MSD coil differences
I had purchased a MSD ignition coil for my 95 gt and noticed that the MSD coil does not have a second connector i.e. the factory coil has a little round resistor/capacitor? on it with a plug while the MSD does not.
Can someone explain this to me, and if I should just use the factory coil or use the MSD coil?
Thank you,
Chris Wanner
cpwanner103@gmail.com is offline
Old 08-16-2011, 07:23 AM
pepprdog
pepprdog's Avatar
Use the MSD coil! MSD designed the system to be used as is, don't mess with adding anything into their system.
pepprdog is offline
Old 08-17-2011, 12:11 AM
petrock
petrock's Avatar
Unless your motor is heavily mod'd, the MSD coil is overkill and won't make a noticeable difference in performance. As for the little plug, its on the motor for a reason... So it is probably needed. Contact MSD, or go back to stock.
petrock is offline
Old 08-17-2011, 01:26 PM
Anyone know what the little plug is called, or why my engine would require it?
Old 08-19-2011, 12:12 PM
Turns out the MSD coil was a factory dud, so that explains that.
drfister
05-03-2018 10:38 PM
musnicki
09-23-2015 07:11 AM
iculookin
09-02-2015 12:34 PM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Stock Ignition Coil/MSD coil differences
