2006 Power Seat
2006 Power Seat
Folks:
I just bought a 2006 4.0 L that needs some work.
The car originally came with manual seats. I picked up a set of seats from craigslist with a drivers side power unit. I plugged it in and bolted it down
but it wont come to life. I swapped the 30 amp fuse in position 14 but still no luck.
Not sure if the harness is not compatible or the seat motor is dead.
Any advice?
Thanks
Any advice?
Thanks
I had a little luck with the wiring diagrams.
Looks like the ground goes to G204 which is behind the left hand foot well trim panel.
The power connects to C1035D which is the Bussed Electrical Center
at the front of the underhood fuse box. Not sure how to tie into that yet.
On the diagram I hace it says 11-1. Not sure if that refers to a location in the box.
Need to research how to modify the underseat connector C3111 to accept 2 more wires.
Also need to know how to rout wire through firewall and what size wire i need.
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
