Swapping a 3.8 for a 5.0 in a 1995 Mustang
Old 08-31-2011, 09:57 PM
Ford1995Black
Ford1995Black's Avatar
Default Swapping a 3.8 for a 5.0 in a 1995 Mustang
Im wondering if it is possible to swap my 3.8 liter V6 with a 5.0 V8. My 1995 Mustang was originaly a 6 cylinder, and I've heard that it is impossible to do the swap because of some electrical configuration. If it is possible, what parts, other than a 5.0 engine, do I need?
Ford1995Black is offline
Old 09-01-2011, 12:03 AM
JIM5.0
JIM5.0's Avatar
It is not impossible. Some modder shops have actually done it..
If you do. just get all the appropriate equipment, including new K member (if this is required for the engine mounts), the electrical harnesses, and so forth.
I assume you are looking at a 5.0 pushrod engine, not a Coyote 5.0. The pushrod 5.0 should be very much straight forward to drop in. The 5.0 Coyote is a different matter altogether.
JIM5.0 is offline
Old 09-01-2011, 08:06 PM
Matt's 95 Stang
Resident Ginger
Matt's 95 Stang's Avatar
Not worth it. The money you will spend swapping over new brakes, suspension, k member, trans, rear-end, electrical, and all other misc stuff will not net you that much more power. The 5.0 had what 225HP, the 3.8 had 135 to the wheel. For the amount you will be spending to do the swap you could forge your 3.8 block, get heads, cam, intakes, and get 300-350HP and be a sweet 6 banger sleeper.
Matthew
Matt's 95 Stang is offline
Urambo Tauro
12-17-2016 03:30 PM
Urambo Tauro
09-07-2015 12:47 PM
ding56
08-14-2015 02:40 AM
StangMuscle
08-12-2015 07:27 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: Swapping a 3.8 for a 5.0 in a 1995 Mustang
