Sponsored by:
Sponsored by: DashLynx
Gear Swap for an 2012 Gt
Old 10-09-2011, 09:39 AM
mack7265
mack7265's Avatar
Default Gear Swap for an 2012 Gt
I swapped the gears from 3.31 to 3.73. I have looked everywhere to see if I have to change something to correct the speedo. Please help.
mack7265 is offline
Old 10-09-2011, 04:43 PM
StangisSwag
StangisSwag's Avatar
is your spedo acting up? i havent heard anything about needed to do that for that kind of gear change
StangisSwag is offline
Old 10-09-2011, 05:44 PM
mack7265
mack7265's Avatar
It just dont feel like the right speed.
mack7265 is offline
Old 10-09-2011, 08:45 PM
Misbehavin
Misbehavin's Avatar
Any gear change will require a speedometer adjustment.
2005-2009 Mustangs require you to adjust the parameters in the tune. Should be the same for 2012 as well. I see you're using a Bama tune, so I'm going to assume you probably have an SCT tuner. Rear gearing is often left adjustable in their tunes. If not, give Bama/AM a call.
Misbehavin is offline
Old 10-10-2011, 01:53 PM
mack7265
mack7265's Avatar
Thanks for the info. I was hoping it was an electronic change and not a speedo gear change.
mack7265 is offline
musnicki
09-23-2015 07:11 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Pyrate Dave
09-10-2015 07:30 PM
vintageaion
09-08-2015 10:45 AM
Webster454
09-07-2015 04:59 AM
Quick Reply: Gear Swap for an 2012 Gt
