just changed my brake pads... lock pin is rusted... just leave it alone?
Old 11-27-2011, 06:02 PM
jd254
jd254's Avatar
Default just changed my brake pads... lock pin is rusted... just leave it alone?
this is on a toyota solara 2005, but that shouldnt matter. after 6 years, brakes just got done for the first time ever.
the back went perfectly. bolt was long and lubed.
the front... the bottom lock pin is rusted and i can't compress it to slide the caliper in.
the top lock pin on the other side of the front is also.
the bolt that goes into the lock pin was short and unlubed, which leads me to believe that is why the lock pin is rusted.
according to this
http://www.akebonobrakes.com/oem/bra...ed_caliper.gif
the lock pin and guide pins are the same... it's the pin inside the pin boot that compress back and forth freely...
so... I installed all the pads on... which was extremely difficult when the caliper wont go on because I couldn't compress the lock pin... I tested drove the car... everything seems perfect... should I worry about the rusted lock pin that's not compressing?
also I forgot a tiny shim that goes on one of the brake pad, not the caliper mount. write something to let my girlfriend knows that when she dies because of brake failure... it's not because of the shim.
1. should I just leave the rusted lock pin alone?
2. is the tiny 2 cm shim for the brake pad useless?
jd254 is offline
Old 12-05-2011, 11:37 PM
onewheat
onewheat's Avatar
If your caliper pins don't freely slide, you will get uneven pressure and therefore uneven pad wear - probably accelerated wear as well. If you can't free up the pin and plan on keeping it, I'd recommend a new caliper.
onewheat is offline
musnicki
09-23-2015 07:11 AM
97SN95GT
09-13-2015 09:45 PM
whatsup62
09-03-2015 01:38 PM
movielover40
08-27-2015 10:13 PM
antipeterleague
08-18-2015 01:50 PM
Quick Reply: just changed my brake pads... lock pin is rusted... just leave it alone?
