Cd Player Problem Please help
Old 01-23-2012, 08:28 PM
robwit
robwit's Avatar
Unhappy Cd Player Problem Please help
i was playing a cd this morning and all of a sudden the sound cut out. the player was showing "Err" so i tried ejecting it but it kept saying "Err". what could the problem be?
robwit is offline
Old 01-24-2012, 10:29 AM
ttocs
ttocs's Avatar
stock or what brand? Really the only thing you can hope will work is to disconnect power to it and hope it resets itself or some brands will have a reset button to push behind the faceplate. It is not uncommon for them to sometimes get just far enough out of alignment that the unit thinks something is wrong and shuts down to keep from doing further damage. When you reconnect power to it, you will probably hear the loading mechanism move, and it may eject your disc at the same time. You can either pull the hrns on the back of the deck or disconnect the fuse or battery. No I do not know which fuse to pull.
If it is an aftermarket unit look behind the faceplace for a micro switch and use a pen/pencil to push it in for a couple of seconds. When releasing it again you should hear the loading mech cycle and hopefully eject your disc.
ttocs is offline
Old 01-25-2012, 03:59 PM
cameornh
cameornh's Avatar
+1 to ttocs. The fuse should be on the same circuit as the dome light. or just pull the negitive cable on the battery.
cameornh is offline
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
vbonina
09-22-2015 08:31 AM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: Cd Player Problem Please help
