Parking brake popping noise!
So, I hate to make my second post here a tech question, but here goes. I was parking my 2010 GT 5-speed today and when I set the parking brake, it made a loud popping noise. It seems to be working fine though. I even put her in 1st and tried to apply a little gas, and it's holding firm when it's set, and releases completely when I do so. I can't tell if it's my imagination now or not, but there may be just a bit more play in the handle. Anyone know what might have happened? It's eating away at me!
If it is indeed the parking brake assembly, it has a balance bar so if one side broke loose then at least the other would still be operational, you could also check by jacking up the rear end, putting on the e-brake and trying to turn either side to see which side broke loose. But take her in anyways, you payed for the warranty you must as well use it. RockNRolla : )
09-16-2015 07:53 PM
LivingInThePast
09-16-2015 12:20 PM
