Do u guys use rtv silicone when replacing gasket? No? Do put it around the seal before you push it into block? Or do u put it on dry and Put some on the outside after the seal is seating in already?
You dont really NEED it for that type of seal, but sometimes I put on a thin coat on the outer surface before installation. Wont do ya much good after you install the seal tho.
I wouldn't use a petroleum based product of any kind on the gasket if the gasket is rubber. It will degrade the rubber and cause a leak over time.
The rear main seal is in constant contact with engine oil. How is putting a light coat of vaseline or engine oil around the metal ridge of the seal is going to degrade the seal ?
