Sponsored by:
Sponsored by: DashLynx
Just put the OR/H pipe on.
Old 05-28-2012, 01:04 PM
JGill1992
JGill1992's Avatar
Smile Just put the OR/H pipe on.
Took me about 2 hours in my backyard with a socket wrench lol. Went on pretty good. I'll post a video on this thread later today.
Stock headers, summit racing off road H, flowmaster 40 axelback.
JGill1992 is offline
Old 05-28-2012, 01:17 PM
JGill1992
JGill1992's Avatar
Ok it sounds really .. Not sure how to describe it rattley maybe. I posted a video on you tube maybe someone can tell me what I did wrong. Hummm
Old 05-28-2012, 01:19 PM
JGill1992
JGill1992's Avatar
http://www.youtube.com/watch?v=nqPF9...e_gdata_player. I JUST uploaded so YouTube may have to process if for a little bit
Old 05-28-2012, 01:33 PM
Roush05
Roush05's Avatar
Sounds like a small exhaust leak maybe. Do you have all the bolts torqued down tight?
Roush05 is offline
Old 05-28-2012, 01:36 PM
JGill1992
JGill1992's Avatar
Thats what I thought it sounded like I double check everything tonight. At low speeds it sounds AWESOME
Old 05-28-2012, 01:50 PM
Roush05
Roush05's Avatar
Make sure the clamp is on tightly too. Also, my current setup has a tiny rattle if i accelerate at low RPMs in 5th. Not sure what causes it.
edit: glad you like it though!
Roush05 is offline
Old 05-28-2012, 04:21 PM
JGill1992
JGill1992's Avatar
Should they all be as tight as possible?
Old 05-28-2012, 05:08 PM
Roush05
Roush05's Avatar
There are probably specs that they should be torqued down to, but I would just make sure they're plenty tight. When I first fired up my headers after their install, we had forgotten to torque down 2 studs and there was a huge leak. Just tighten as much as you can without breaking the bolt. lol.
Roush05 is offline
Old 05-28-2012, 05:35 PM
JGill1992
JGill1992's Avatar
it sounds like its coming from the back ill have to jack it up again and take a look.
I blew out a tire on my test run (hit a huge screw) and i dont have a spare. it Held air long enough to get home but its not going anywear till i get that fixed and all the tire shops are closed today haha. and i let my parrents borrow my van for a road trip lol. just my luck
Old 05-28-2012, 05:43 PM
Roush05
Roush05's Avatar
Wow lol, talk about bad luck :/ If it's in the back, it's got to be either your clamp between the two halves of the pipe or one of the two clamps between the h pipe and the over axle pipe.
Roush05 is offline
Quick Reply: Just put the OR/H pipe on.
