what are them thing ma bobs called and where can io order them?
Old 06-20-2012, 05:27 PM
SkipS
SkipS's Avatar
Default what are them thing ma bobs called and where can io order them?
I have a stock 2002 v6 that was left for dead by my son in law. Im returning it back to glory . I have ordered most of what i need to complete the project but I cant find the short section of the stock lower skirt that fits on the bottom of the fender in front of the doors. the car has the rest of the skirt that runs from the bottom of the door back to the rear fender . Whats the correct name for that section or part, and where can I get it? thanks in advance!........skip
SkipS is offline
Old 06-20-2012, 07:20 PM
Torch_Vert
Torch_Vert's Avatar
Correct term would be "rocker molding" (you'll need to specify you need the front section and which side if you start calling around). Best bet would probably be a salvage yard. You can probably still get it from Ford, but the salvage route would be cheaper.
Torch_Vert is offline
Old 06-21-2012, 05:24 AM
SkipS
SkipS's Avatar
thanks ill check the local yards this weekend. I ordered the headlights, and the header panel and the bra. thats the last three things then the transformation back to its former self will be complete
SkipS is offline
Tivo304
08-28-2023 12:19 PM
Pyrate Dave
09-10-2015 07:30 PM
mustangchef
09-04-2015 08:08 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
09-02-2015 08:40 PM
Quick Reply: what are them thing ma bobs called and where can io order them?
