Bogs out and dies when clutch is let out
I have a 1988 5.0L mustang LX, and for some odd reason the car will bog out and shutter violently when driving then as soon as i put the clutch back in the shuttering and bogging stops, then i let the clutch out again and it will bog out and die. Any ideas as to what this might be?
It could have a warped clutch disc. My 67 did that for awhile and it was only in 1st gear. So I started taking off in 2nd gear and after a couple days I could use 1st and it wouldnt buck and bog down. Using 2nd gear helped wear the disc level faster. Might try that and see if it helps any.
Possibly a bad clutch cable not providing enough resistance? I had a similar problem when I replaced the stock quadrant and the stock cable with an adjustable one. Made a big difference in every day driveability.
junior04
09-28-2015 10:53 AM
