cant remove distributor. please help me. im stupid. - Page 3 - MustangForums.com
Sponsored by:
Sponsored by:
Old 01-01-2013, 11:46 PM   #21
Bosnjak
CHECK IF THE CRANK IS OK OR NOT?? IF NOT THEN IT WOULD NEED REPLACEMENT AND I AM SURE THAT YOU WILL CERTAINELY GET SOLVED BY YOUR PROBLEMS.....
Bosnjak is offline   Reply With Quote
Old 01-02-2013, 03:06 AM   #22
bluebeastsrt
bluebeastsrt's Avatar
As far as I can tell from your photos everything looks OK. Looks like alot of burn oil was causing the problem with the base of the distributor sealing to the block. Cam gear looks real good in the photo.
bluebeastsrt is online now   Reply With Quote
Old 07-17-2014, 12:41 PM   #23
9550
9550's Avatar
so, i may be dumber than i thought.
i for some reason thought that there should be a gasket in section B below, but now im pretty sure theres only supposed to be a gasket in section A?
make sense?
thanks for any confirmation
[IMG][/IMG]
9550 is offline   Reply With Quote
Old 07-18-2014, 08:23 AM   #24
88 orangepeel notch
88 orangepeel notch's Avatar
Yes, just an o-ring in the yellow area, that's all.
88 orangepeel notch is offline   Reply With Quote
Old 07-18-2014, 09:57 AM   #25
9550
9550's Avatar
Quote:
thanks brother
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 04:23 PM
Bad cylinder? Dathan V6 (1994-2004) Mustangs 4 10-05-2015 05:52 AM
Rear Package Shelf jrrhd73must Classic Mustang General Discussion 2 10-02-2015 09:17 PM
Hi - Yes, I'm a gal and need help CS2007 General Tech 7 09-29-2015 07:38 PM
Hello All RCS02v6 New Member Area 4 09-29-2015 01:46 PM
