Drivetrain Strength?
I've had my car for about a month now and am finally figuring out how to drive it. I'm getting better at my launches but I'm worried about just how much the drivetrain will take.
Do these cars have a habit of breaking input shafts, drive shafts, u-joints or rear ends?
The most that I've left the line at was 2,000 rpm. This is due to me worrying about catastrophic failure as well as traction on the street. Any guidance you guys can give would be great.
Thanks
Thanks
What kind of tires? I wouldn't worry about it too much at your torque level.. However, you should always prepare to pay to play.. If you want to race it, you need to be ready to fix it in the event something does happen since anything can happen.
I'm not afraid to pay to play but sometimes it's cheaper to upgrade before parts are broken than it is to to a rebuild or replace.
In my experience.. you should be fine launching with street tires. If you were using real sticky tires and putting all that torque directly on the drivetrain you could probably end up hurting something.. And I agree with upgrading things before they break but in the case of the transmission it would be the same price either way you look at it (except for the cost to tow the car home if it decides to grenade on the track). You could always beef it up a little, built 3650 and a good aluminum DS would run in the market of 2500 or so.. Some people worry about the rear end, I've never seen a problem with the stock 8.8 at levels under 500rwtq.. Really things to get too sketchy until you start wanting to stick and launching really hard.
09-17-2015 07:57 PM
09-17-2015 07:32 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
