O2 bypass?
O2 bypass?
This is for my 03 Ranger, not my Mustang.
I'm throwing a code for O2's. There's 4, 2 pre cat and 2 post cat before the Y pipe. the front one on the right bank is between the block and ac compressor and there's really no way to get it off without unbolting the plumbing from the manifold. Is there any way (emissions be damned) that I can fool the computer? Like can I plug up a new O2 sensor and ty wrap it up into the wheel well or the frame?
I'd first make sure that the problem really is the O2 sensor. It could very well be a wiring issue or exhaust leak which may be easier and much cheaper to fix. Otherwise, I would try to figure out how to replace the faulty O2 sensor correctly. Maybe use a crows foot, swivel extension and/or similar tool(s) to remove it.
Good luck...
