Reason behind this?
Reason behind this?
Well I think this one id the best place to discuss about my latest problem, actually from couple of days when I hit the break I just feel jerk on the steering wheel but not able to find the exact reason. Any idea?
Well friends thanks for your response I checked all these stuffs and find that the rotor has wrecked and there is also some kind of rust over caliper but the brake pad is fine. One thing I would like to know I should also replace caliper only because of rust or not?
If it's on the outside I wouldn't worry about it, it's just going to look nasty. As long as the lines going to it are good you don't have to worry. If you went as far as to look into the piston(s) in the caliper and discovered rust, however, I would have it re-conditioned/replaced.
Matt's 95 Stang
10-05-2015 07:16 AM
