Considering that as part of being a moderator is policing giant sigs, u may want to check yourself if you like being a member here, if you can't take a bit of sarcasm, get off the forums would be my suggestion.
Do wat you feel you have to do if your going to use your moderator status to threaten me im not scared with your intimidation tactics if you feel like thats what you have to do to make a point then by all means go right ahead if being a moderater gives you the right to threaten me by taking my account and using sarcasm part of ur job description then i guess you win but you would have gotten alot further with just a little kindness.
when i took off my chrome 5.0 badges i used denatured alcohol and it ate through the double sided 3M tape/foam residue and took the the adhesive right off then used a sponge and soapy water and cleaned the area. Did not hurt the paint and worked great.
