Sponsored by:
Sponsored by: DashLynx
Gauge question.
Old 12-15-2012, 12:06 PM
Trizoy
Trizoy's Avatar
Default Gauge question.
I was wondering if anyone knows where I can find info on what I should set some gauges at? I have a 08 Mustang GT with a Edelbrock E-Force supercharger on a stock 4.6 block. My question is what should I set the oil pressure and boost limits to? I've heard the E-force puts out 5 or 6 pounds of boost but I can't find it in writing. Any help would be great. Thanks
Trizoy is offline
Old 12-21-2012, 07:59 PM
Trizoy
Trizoy's Avatar
Or I can just figure it out on my own....
Trizoy is offline
Old 12-21-2012, 08:16 PM
LilRoush
LilRoush's Avatar
My understanding is the E Force uses the Eaton 2300 TVS compressor unit and is roughly 5-6 psi (depending on air temp).
I wouldn't be worried about a specfic boost level (as it's just a measure of restriction in the air flow). I'd look at the actual rwhp/rwtq number you put down after the tune, and make sure you're not over powering the stock bottom end.
If you want to adjust boost, it's all in the pulley size (smaller gives you more boost, bigger gives you less).
LilRoush is offline
Old 12-21-2012, 11:34 PM
T.Richardson
T.Richardson's Avatar
I wonder, do they come with an intercooler?
T.Richardson is offline
Old 12-22-2012, 04:37 PM
Trizoy
Trizoy's Avatar
Thanks for the intel. I appreciate it.
Yes
Some info: http://www.edelbrock.com/automotive_...injected.shtml
Trizoy is offline
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
Quick Reply: Gauge question.
