Sponsored by:
Sponsored by: DashLynx
Help with No start after replacing heater core
Old 04-02-2013, 12:39 AM
blknismo180
blknismo180's Avatar
Default Help with No start after replacing heater core
Just did a bunch of work on my 00 v6. Rebuilt the heads and replaced the heater core which involves removing the dash and electrical connectors.
No start I hear a whine from the engine bay when I first try to crank it. The engine doesn't crank
Also on the inside, the drivers seat track does not move as if there is no power
The glove box trunk release doesn't work.
Could everything be electrical? Anyone know where I can start
Everything is plugged in
blknismo180 is offline
Old 04-02-2013, 02:34 AM
Js88lx
Js88lx's Avatar
Is the battery charged good.?
Js88lx is offline
Old 04-02-2013, 07:20 PM
blknismo180
I wouldn't say the battery is charged good but, I think it would at least have power to move the seats... the radio and lights turn on
Old 04-03-2013, 02:20 PM
AutoPart-Performance
Former Sponsor
AutoPart-Performance's Avatar
Did you forget to hook back up a ground wire? What is the battery voltage? Needs to be at least 11.5 volts.
AutoPart-Performance is offline
Old 04-03-2013, 02:55 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Check the grounds and make sure ALL connectors are plugged back in securely including that none of the pins from the connectors have backed out. Radio and lights draw very little current. However. since even the trunk release wont work (very little current there too), i'm sticking with a bad connetion or ground.
Derf00 is offline
Old 04-04-2013, 01:11 AM
petrock
petrock's Avatar
To start a car, it needs to be between 12.4 & 12.8 volts.
If the battery is fully charged and you still have this problem then you probably forgot to reconnect something. Good luck...
petrock is offline
djbigskrilla
09-20-2022 01:04 AM
ShaneB26154
35
03-04-2021 04:05 AM
Calizic
08-28-2015 01:46 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: Help with No start after replacing heater core
