Sponsored by:
Sponsored by: DashLynx
Is this harmful or dangerous?
Old 04-20-2013, 10:45 AM
Vader99
Vader99's Avatar
Default Is this harmful or dangerous?
Does that head gasket repair stuff you can buy almost everywhere work at all or is it too risky. I have a small coolant leak near the front of the passenger side head under the intake manifold right at the head gasket. I'm just wondering if it's worth trying or is it potentially harmful and I should just suck it up and put it in the shop or fix it myself?
Vader99 is offline
Old 04-20-2013, 06:08 PM
Vader99
Vader99's Avatar
Wow, seriously 100+ views and no replies? Help me out here
Vader99 is offline
Old 04-20-2013, 06:16 PM
CPTCO
CPTCO's Avatar
You should probably just suck it up and fix it yourself. If you are dead set on trying to seal it, use some stuff called (I haven't bout it for years so forgive me if I'm wrong) K & M or K & W Head Sealer. Comes in a can about the size of a soda. I've used it before and it has worked. But plan on plugging off the heater core before you use it.
CPTCO is offline
Old 04-20-2013, 08:32 PM
Torch_Vert
Torch_Vert's Avatar
It's K&W, and you're right that it might work, but the material sure won't do the cooling system passages any favors.
I concur better to bite the bullet and do a proper fix.
Torch_Vert is offline
Old 04-20-2013, 10:40 PM
tinman
tinman's Avatar
Leaky gaskets are repaired by replacement, not from a can of crap from the store.
Shop time for you unless you care to get your hands dirty..........
tinman is offline
Old 04-20-2013, 10:41 PM
Vader99
Vader99's Avatar
Well, upon further inspection I was wrong, it's not the head gasket at all. It's leaking from the intake manifold and dripping down on the side of the head.
Vader99 is offline
Old 04-23-2013, 11:53 PM
blacknred93
blacknred93's Avatar
just get a gasket set
blacknred93 is offline
Old 04-24-2013, 07:18 AM
Vader99
Vader99's Avatar
It's leaking from a the intake manifold at the front across from the thermostat. The head gaskets aren't leaking.
Vader99 is offline
Old 04-24-2013, 08:51 AM
musicbox
musicbox's Avatar
Are your manifold gaskets worn or leaking? Try replacing those. Might as well do them both. You could just replace the one that's leaking, but why leave an old one that's just as susceptible to leak. Saves time and money in the future.
musicbox is offline
ChampInSD
10-02-2015 04:55 AM
TwoSixSided
09-05-2015 10:44 AM
jpplaw
08-22-2015 09:29 PM
Quick Reply: Is this harmful or dangerous?
