grind noise when turning 2000 stang
Old 09-15-2013, 06:34 PM
blknismo180
blknismo180's Avatar
Default grind noise when turning 2000 stang
Leaving work today I heard a weird when turning... Binding/grind noise in one spot while turning. Lifted the front end to take a look and the noise goes away... So it only does when on the ground and its hard to tell what it might be. Mostly does it when turning left. Any ideas or things I could check
blknismo180 is offline
Old 09-15-2013, 11:56 PM
petrock
petrock's Avatar
When you lifted the front end to test it, did you lift it from the frame or the lower control arms? I would do it from the lower control arms (both of them) so that the suspension is still at normal ride height. The grinding could be the wheels, rotor, caliper and/or something rubbing against something else as the wheel spins.
I’d jack up the front via both lower control arms, put them on jack stands, start the car and turn the wheel to see if it reproduces. If it doesn’t, then try again with a friend spinning the front wheel.
Good luck...
petrock is offline
bjdutch2005
03-24-2017 03:38 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
rksnow1
09-14-2015 08:46 PM
Jose Corretjer
09-08-2015 06:32 AM
Quick Reply: grind noise when turning 2000 stang
