Mustang drivin me crazy.
Old 01-01-2014, 05:26 PM
Mike Horne
Mike Horne's Avatar
Default Mustang drivin me crazy.
I have a 2001 V6 convertible. This thing randomly jumps and bucks and stalls It will buck going the the road but it only does it once or twice and it might go a long time before it does it again. There is absolutely no pattern. The check engine light is not on a scan shows no codes. I have replaced fuel filter coil pack plugs and wires. I have cleaned the IAC motor and throttle body. I have been workin on cars a long time but this one has me puzzeled. Anybody had this problem before??
Mike Horne is offline
Old 01-03-2014, 08:37 AM
Mike Horne
Mike Horne's Avatar
Has no one ever run into this problem??
Old 01-14-2014, 10:21 AM
Fryguy22
Fryguy22's Avatar
Try cleaning the MAF with MAF specific cleaner. Also, try to replace your IAC, cleaning only works about half the time. If it doesn't fix it, return it.
Fryguy22 is offline
Old 01-15-2014, 02:35 PM
Mike Horne
Mike Horne's Avatar
Thanks I found the problem last week. It was the part that replaced the distributor it drives the oil pump. I pulled the cam sensor off and the cavity under the sensor was full of metal.. The bushings had worn out causing it to try to lock up once in a while replaced it and it runs as good as it ever did. No problems at all now..
Old 01-16-2014, 02:28 PM
Fryguy22
Fryguy22's Avatar
Awesome, glad you fixed it.
Fryguy22 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
01-06-2016 07:03 PM
chain
08-17-2015 08:52 AM
daytooday
08-11-2015 09:22 AM
Quick Reply: Mustang drivin me crazy.
