Sponsored by:
Sponsored by: DashLynx
Mustang won't start after disconnecting the battery
Old 02-05-2014, 06:24 AM
Ericccc
Ericccc's Avatar
Default Mustang won't start after disconnecting the battery
Hi, new member, treat me nicely
So, I've got a Ford Mustang GT 2007 that I disconnected the battery from. This was a horrible mistake, because now it won't start.
I've checked both the battery and tried a new battery with no luck, the engine doesn't crank at all. There is no sign of life and a slight "clicking" or "tapping" noise coming from under the dashboard almost at all times.
I spent yesterday crawling under it and confirmed that the starter doesn't get any power.
The SecuriLock icon is slowly flashing on the instrument cluster.
I've got the feeling that it's something with the SecuriLock or some aftermarket alarm system that shut it down thinking it was a theft attempt - but I am not certain.
Is there anyone who's got any suggestions how to fix this?
It would be greatly appreciated.
My apologies for possible spelling errors, english is not my first language.
Thanks a lot!
Eric
Ericccc is offline
Old 02-05-2014, 08:54 AM
massguy54
massguy54's Avatar
is the battery charged
massguy54 is offline
Old 02-05-2014, 09:55 AM
Ericccc
Ericccc's Avatar
Both of the batteries were completely charged when trying them out.
Ericccc is offline
Old 02-05-2014, 10:18 AM
AzPete
AzPete's Avatar
Do the lights, radio, door chime....anything work? If nothing works, most likely battery connection issues. If lights work, do they dim when turning tge key to start? Does it have more alarm than the factory setup?
AzPete is offline
Old 02-05-2014, 01:36 PM
WJBertrand
WJBertrand's Avatar
Did you reconnect the battery? <kidding?> Manual transmission? Pushing the clutch pedal down far enough?
WJBertrand is offline
Old 02-06-2014, 01:17 AM
Ericccc
Ericccc's Avatar
Radio, lights, heating, door chime.. Everything works. The lights doesn't dim when I try to start the car, but the car is completely silent, not a single sign of life from the engine.
It's an automatic.
I'm not completely sure actually about a possible aftermarket/dealership alarm, it's a CA import (I think) and I have lots of papers to go through (and the previous owner might still have some papers to send me, he's still going through the stuff he got when importing it). I've searched some for a switch or button for a possible reset of this but no luck yet.
Ericccc is offline
Old 02-06-2014, 01:54 AM
Ericccc
Ericccc's Avatar
And yes, I reconnected the battery :P
Ericccc is offline
Old 02-06-2014, 02:37 PM
AzPete
AzPete's Avatar
Have you checked the wires on the starter to ensure they are tight? No dimming of the lights when the key is turned indicates no power being applied to the starter. Are you sure the cables are goo? Some have been known to corrode inside the insulation.
AzPete is offline
Old 02-09-2014, 08:06 AM
Number4
Number4's Avatar
Thanks a lot!
Eric
Cables can corrode. Sometimes you can't tell by looking. One test is to bend the cable back and forth. Assuming your weather is above freezing, the cables should bend easily. If they crackle as you bend them, then corrosion has worked its way down. Also, primary ground could be bad. Clean or run a new ground. This may not have been an issue until you disturbed the cables.
Number4 is offline
Old 11-11-2017, 07:27 PM
Matthew Smith
Matthew Smith's Avatar
did you ever figure it out what was the problem
Matthew Smith is offline
jjwinel78
08-17-2015 03:34 PM
KEM Motorworks
08-14-2015 10:13 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
UINZWAY
S197 Shelby Section
08-05-2015 10:34 PM
Quick Reply: Mustang won't start after disconnecting the battery
