Sponsored by:
Sponsored by: DashLynx
loud when accelerating
Old 02-15-2014, 10:44 AM
Majaski
Majaski's Avatar
Default loud when accelerating
im looking to buy a 2005 mustang gt and when i accelerated during the test drive it makes a really loud noise in the cabin. it has an airaid cold air intake could that be the problem.
Majaski is offline
Old 02-15-2014, 11:11 AM
pkugrsq
pkugrsq's Avatar
If you floored the car, the cold air would have made a difference. Otherwise, it's all part of the exhaust, whether its the drone at low rpms or an aftermarket exhaust. If its not either of those, then the factory exhaust is leaking somewhere.
pkugrsq is offline
Old 02-15-2014, 11:23 AM
Majaski
Majaski's Avatar
the exhaust is stock, how would i be able to tell if there is a leak
Majaski is offline
Old 02-15-2014, 12:51 PM
pkugrsq
pkugrsq's Avatar
You should be able to jack the car up and look around. Most likely, if the previous owner hasn't gotten the underside roughed up, it's just a loose bolt causing some opening between some joints. Though GTs are generally louder than other stock cars.
pkugrsq is offline
Old 02-16-2014, 11:30 AM
Majaski
Majaski's Avatar
it doesnt seem to have a leak it sounds fine while idling and the underside is in good condition. i test drove another one and it was much quieter so im thinking i just need to replace the airbox
Majaski is offline
mtgldr
02-03-2024 09:00 PM
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
MustangV6P
09-28-2015 11:00 PM
Quick Reply: loud when accelerating
