Rough turning on 67 with 5.0 power steering pump
Old 02-27-2014, 03:43 PM
Vonna Kay
Vonna Kay's Avatar
Default Rough turning on 67 with 5.0 power steering pump
We are restoring a 67 mustang that has a 93 5.0 engine. We are having issues with the 5.0 power steering pump. It is rough turning either direction and will continue turn when you let go of the wheel. Is there a way to decrease pressure or the volume or both on the pump? Any suggestions will be appreciated. Thanks. Lavonna
Vonna Kay is offline
Old 02-27-2014, 03:45 PM
Vonna Kay
Vonna Kay's Avatar
I forgot to mention that it 67 power assisted steering with a 5.0 pump. Lavonna
Old 02-27-2014, 05:52 PM
88Mach1
88Mach1's Avatar
are you sure you have lines correct? i accidentally had the lines backwards once, and it acted like you described.
besides that though, i have a 92 5.0 engine in my 69 and the 5.0 pump works great.
88Mach1 is offline
Old 02-28-2014, 12:34 PM
Vonna Kay
Vonna Kay's Avatar
We actually had them on backwards before and the problem was worse. Even after switching them to correct position, we are still having problems. Sounds like you have the exact same set up. Did you have to do anything differently to the pump such as reducing pressure? Thanks for your help. Lavonna
Old 03-01-2014, 04:40 PM
88Mach1
88Mach1's Avatar
no, i didn't do anything that would affect the pressure. i just hooked the lines up like normal and that was it. since you have the lines on correctly, i don't know what could be the problem.
88Mach1 is offline
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
labudski
08-24-2015 07:23 AM
jpplaw
08-22-2015 09:29 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: Rough turning on 67 with 5.0 power steering pump
