help 95 fuel pump no power
Would find out the wiring circuit for the fuel pump relay. its part of the ccrm. and check its circuit. You maybe able to have someone cycle the key and see if its clicking. Also most fuel circuits actually go thru 2 different fuses. I for control power and 1 for the load. So may want to double check all the fuses. If relay isnt clicking may have to check ignition circuit.
[QUOTE=bryan67;8358235]Would find out the wiring circuit for the fuel pump relay. its part of the ccrm. and check its circuit. You maybe able to have someone cycle the key and see if its clicking. Also most fuel circuits actually go thru 2 different fuses. I for control power and 1 for the load. So may want to double check all the fuses. If relay isnt clicking may have to check ignition circuit.[/QUOTE/]
I have checked all the fuses and all of the pins in the fuse box and the ccrm the only thing not sending out power is pin 5
uberstang1
09-20-2015 06:42 PM
