Shifting from 1st-2nd, 2nd-3rd and 3rd-2nd - NOT GOOD :(
Something else that will likely help is a "Clutch Pedal Extension" ..... seems expensive, but it works. Your brake doesn't go to the floor so why should the clutch? Both legs start at the same hip in the same seat. Back in the day the clutch pedal was higher at rest than the brake, that still works.
http://www.shop.bondraperformanceengineering.com/
I looked at different options, like just installing a polyurethane bushing only OR changing the shifter itself and decided to change the shifter. I'll post back here when it is done and share if it solved the issue.
Thanks.
did shifter and trans mount at same time. My trans mount filler slipped right in. Dont really notice any extra noise of Vibration from it. Hear from guys were if its tight they have been getting some. so they have been cutting off the flat tab. theres a few post on it here and on the Moddedmustang.
whiteline trans bushing filler
If you get the whiteline trans mount filler. If you look at it. It has 2 oblong pieces then a flat piece that engage your stock bushing. If you go to install it and and its really tight. Have read on other threads guys have been cutting the flat piece off. Here's a link to a moddedmustang thread about it. theres some pics. of the modified filler on the 3rd page.
http://www.moddedmustangs.com/forums...-review-3.html
@tbear853 ..... Thanks for the detailed post and background info. I've graduated from manual Volkswagen, Toyota Land Cruisers and other manual/standard vehicles. I stopped driving the manual shifts when I came to US and now I've bought a manual tranny car after a long while. Also, this is my first performance oriented car (or a car with 8 cylinders) so I agree with you that my technique will get better with time. BUT frankly, I wasn't expecting this from Ford. I plan to add a shifter (already ordered) and the transmission mount to make it feel as best as it can. My wife, currently deosn't like sitting in the car because of the issues with transmission. She won't even drive it - so I need to get things fixed. I plan to keep the car for a long time and won't be travelling alone all the time
@bryan67 ... Thanks for this info. I've received the transmission mount and plan to install it over the weekend. The shifter arrives sometime next week or the week after. I hope this will make things better.
Although, on a side note, I just installed a 2-1/8" circular shift **** - I think it has a much better grip than the factory shift ****. Just my 2cents!
Just installed the transmission mount bushing. I can actually shift from 3rd - 2nd - HOW COME FORD DIDN"T THINK OF THIS ???
All the shifts from 1st-2nd, 2nd-3rd, 3rd-4th and 4th-3rd, 3rd-2nd are 90% improved. Especially while slowing down - 2nd-1st is still slight notchy but I think thats me and not the transmission. My issue with shifting from 1st-2nd while taking a turn is resolved. Overall, I will say it has improved a lot - not 100% which I was anticipating but a little less. Nothing I can't live with.
I didn't modify the bushing at all and installed it as is. There is a slight increase in NVH but I can live with that however, I will try to take out 3/8" from the center tab and see how it responds. I can see why there is a problem with this part of the bushing. But as it stands at the moment, NVH is about +10% - OH and the clutch takeoff is much improved - the thing actually feels connected to the driveline now! I'm Happy
Now awaiting the MGW short shifter to see how that will help me.
Thanks for all your help and suggestions. I didn't even know this bushing existed. A big THANK YOU to all my friends at this and other forums who have suggested this mod.
A little update ..... I have modified the whiteline bushing by cutting off the middle tab that was extending. I can't feel the vibrations in the floor anymore so any NVH I felt after I installed the bushing intially is all gone now. I'll go a little more trimming next time when I install the shifter. HAPPY
