Sponsored by:
Sponsored by: DashLynx
having trouble with the brakes PLEASE HELP!!!!!!!!!!!!!!!!!!
Old 04-12-2014, 08:36 PM
97mustanggt1985
97mustanggt1985's Avatar
Exclamation having trouble with the brakes PLEASE HELP!!!!!!!!!!!!!!!!!!
HAVING TROUBLE WITH MY BRAKES!!!
THE MATER CYLINDER AND THE HYDRO BOOSTER AND THE PROPORTIONING VALVE HAVE BEEN REPLACED. BRAKE FLUID IS NOT GOING THROUGH THE LINES, THE LINES HAVE ALREADY BEEN BLEEDED. THE BRAKE PEDAL STAYS AT THE BOTTOM AND THE BRAKE WHERE THE CALIPER IS IS CLAMPED CLOSED AS IF I WERE PRESSING ON THE BRAKES!!! I AM AT THE EDGE OF MY ROPE, DESPERATELY NEED SOME ADVICE AS TO WHAT IT COULD BE.
97mustanggt1985 is offline
Old 04-13-2014, 07:29 AM
steel pony
steel pony's Avatar
did you bench bleed the master cylinder or just replace it?
Try uninstalling the master cylinder and removing the pushrod assembly in it to properly prime that system.
steel pony is offline
Old 04-14-2014, 09:37 PM
tw1234
tw1234's Avatar
As mentioned before the master cylinder must be bench bled to remove all air from it before installing.
You mentioned you changed the brake booster. There is a booster pushrod adjustment that may need to be done to it to bring it into spec with your old one. From what I've read, you start the engine to supply vacuum to the booster and check the measurement. A gauge can be made that straddles the booster and allows the pushrod to touch it with approx. 5 psi tension. The measurement should read 0.98" - 0.995".
http://www.bing.com/images/search?q=...electedIndex=7
http://www.bing.com/images/search?q=...electedIndex=8
You also mention only "one" brake caliper is not releasing the rotor. It could be an internally collapsed brake hose. They may allow brake fluid under pressure to the caliper but not allow the fluid to return due to the restriction.
tw1234 is offline
CS2007
06-25-2019 09:45 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: having trouble with the brakes PLEASE HELP!!!!!!!!!!!!!!!!!!
