Help with leak pictures Please - MustangForums.com
Sponsored by:
Sponsored by:
Old 04-17-2014, 04:37 PM   #1
massguy54
Default Help with leak pictures Please
I have an oil leak I thought it was my valve gaskets but after replacing it still leaks.I believe its coming out of this black rubber gasket thing right by the oil plug.can anyone tell me what it is and do these have a tendency to leak every now and then.It seems loose and I can move it around
massguy54 is offline   Reply With Quote
Old 04-17-2014, 07:21 PM   #2
massguy54
anyone
Old 04-18-2014, 07:21 AM   #3
dawson1112
THat rubber plug looks like it is in the bell housing so Im guessing you have a rear main seal that is leaking.
dawson1112 is online now   Reply With Quote
Old 04-19-2014, 10:15 PM   #4
tw1234
Could be as stated a rear main seal. Check your PCV system, if it's still being used, looking at your mods, and make sure something isn't plugged causing high crankcase pressure.
tw1234 is offline   Reply With Quote
What is the tube coming out of the air intake that goes to the small box? daltron 5.0L GT S550 Tech 17 04-28-2016 08:10 PM
Vintage AC shop referral - frontrunner serpentine system bradleyb Classic Mustangs (Tech) 3 11-27-2015 07:50 PM
2014 convertible water drains jerrytubes 2005-2014 Mustangs 2 10-23-2015 12:11 PM
Vintage AC shop referral in los angeles bradleyb California Regional Chapter 0 10-01-2015 01:02 AM
Rough idle and vibrating 4cylinderplus2 V6 (1994-2004) Mustangs 9 09-30-2015 05:26 PM
