4.10 gears for 2006 Roush
Old 05-02-2014, 01:13 PM
caneboy
caneboy's Avatar
Default 4.10 gears for 2006 Roush
Well I got some bad news today. I had a noise in the rear end and it seems I need a rebuild. So now is the time to change gears I think. My question is do I get 4.10's? I drive a lot of highway miles and reach cruising speeds of 90 mph. Is the 410 a good gear for me? Or because of my high speed on the highway is a 3.73 better? I still want good pull out of the hole.
caneboy is offline
Old 05-02-2014, 03:19 PM
LilRoush
LilRoush's Avatar
Depends on what you want. I like my 3.55s for the highway. Personally, I wouldn't go steeper than 3.73 gearing.
LilRoush is offline
Old 05-02-2014, 03:28 PM
AJ06GT
AJ06GT's Avatar
If you plan to be driving 90 frequently, then 4.10s might be a bit much, maybe 3.73s would be better. I'd suggest 4.10s for people doing less highway miles or at speeds more like 70, but I think your revs might be a bit high cruising at 90.
AJ06GT is offline
Old 05-02-2014, 08:02 PM
CPTCO
CPTCO's Avatar
FWIW I love my 4.10s. Might have a slight traction problem...
If you don't care what gas costs go for it. I drive mine hard all the time.
CPTCO is offline
Old 05-03-2014, 02:59 AM
caneboy
caneboy's Avatar
I could care less about my MPG that thing that worries me is my high speed freeway driving. Like i said i cruise at 90mph sometimes.
caneboy is offline
Old 05-03-2014, 07:46 AM
steel pony
steel pony's Avatar
I would suggest 3.73 for manual and 4.10 for auto
I'm running 3.73's and frequent the highway daily, usually cruising at 70+ when traffic allows.
steel pony is offline
Old 05-03-2014, 07:51 AM
TheDutchTexan
TheDutchTexan's Avatar
As of late I have been doing a lot of highway miles myself. I have 3.55's, and since yours is a 2006 I believe it still had the 3.55's standard too. It is a great gear imho, and the best all-rounder. They are still ok with the ffrp cams, and they provide decent pull.
With 4.10's I would run a sticky tire. 3.55's on a stock car still chirps into 2nd and 3rd and will spin off the line like the best of em on the stock pirrelli's. I posted this clip not too long ago in the video section, but in case you didn't see it (and to save you some browsing time) here it is:
That time in the video is about a second slow from what a stock mustang should do. But with spinning off the line, traction control on (that worked like it should... aka pretty much not at all) a slight incline and 7 years of fun this is to be expected. I might revisit that spot in the future to try and get a better run in, but it still won't be perfect due to the slight incline.
The thing I love about the 3.55's? 3rd gets you to a 100 near redline, and it still pulls nicely in 4th. 4th nearly hits 140 indicated, but is no where near as fun as 0-100. 5th is pretty much overdrive, no real pull anymore. It still gets to the 145 limiter though.
TheDutchTexan is offline
Old 05-03-2014, 08:26 AM
CPTCO
CPTCO's Avatar
At 90 I'm pulling about 3200 rpm. And if you are worried about top end, mine will still do at least 165.
CPTCO is offline
Old 05-03-2014, 10:19 AM
caneboy
caneboy's Avatar
Damn this hasnt helped lol. I still dont know what gear to get and I have to make up my mind today or tomorrow.
caneboy is offline
Old 05-03-2014, 01:19 PM
E_cox310
E_cox310's Avatar
4.10's are awesome. And if you already have 3.55, 3.73 won't big a big enough jump for you to feel difference. 4.10's can annoy me sometimes when i'm driving on the highway because I have a loud exhaust and I cruise at high speeds too. But at the end of the day I'm glad a changed from 3.55 to 4.10
E_cox310 is offline
Quick Reply: 4.10 gears for 2006 Roush
