Squeaky brakes, what can I do?
Old 05-11-2014, 07:03 PM
rios239
rios239's Avatar
Default Squeaky brakes, what can I do?
Today i changed my passenger caliper and brake pads due to a squeaky noise it makes when the car is running. At first i thought it was the piston sticking on and not retracting back in and thats what made the noise but, to my surprise it still makes that ugly noise. It only does it while driving and when i hit the brakes it stop squeaking, like if the pad rides on the rotor the whole time . I lubbed the back of the pad and pins up. I also jacked the car and turn the wheel and even with slow turning of the wheel it makes a swush swush swush swush swush noise, i feel like the pads and rotor are always making contact. Could it be a master cylinder defect? Is the new piston sticking too do to the master cylinder?
rios239 is offline
Old 05-12-2014, 07:45 PM
tw1234
tw1234's Avatar
If you think the brakes are hanging on and the brake hoses are extremely old they may be starting to collapse internally. Look for heavy rust on the hose where the steel line parts are crimped to the hose.
Check the backing plates to see if they're bent or rusted enough to touch the rotors. Have you checked for looseness, wear and adjusted your wheel bearings if they are adjustable?
tw1234 is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Squeaky brakes, what can I do?
