AC help!! 07 Mustang V6 4.0
I don't think it's the dash switch. When the dash switch goes out isn't it common for the air flow to be stuck in one position (e.g. 1,2,3,4). My air flow completely stops when the car stops. The only air flow I get is when I'm going down the highway (50mph+).
Stupid question...what do you mean by 'free spinning'?
By free spinning I mean the blower wheel just sits on the shaft without spinning when the motor is engaged, the wheel doesn't spin with the shaft. Or when you spin the wheel by hand the shaft doesn't turn.
And...if that is the only time you are getting air (while moving) then the motor is not turning on at all when installed. Dash switch... You've already replaced the resistor and checked your fuses. Dash switch or broken blower wheel are the only other two options I can think of.
The airflow you are getting when driving down the road is simply the air being forced from the outside.
Be back soon!
Ok, I broke down and took it to a shop. They ran a few tests and what not. They said I've got an electrical issue that's preventing power going to the blower motor. Obviously something I don't feel capable of doing. I'm sure they're gonna break me too! Anyways, thanks for all of your help guys!!!
Hey guys, I have been having the same problem with my '05 V6. I have tried a lot of the same approaches as csparks2007 to no avail. I have not tried replacing the dash switch yet, and was hoping to do so. The problem is that every time I search for the dash switch I just pull up chrome switch covers. Is there another name for this part? Thanks guys!
kawiguy827
09-01-2015 07:09 PM
