Sponsored by:
Sponsored by: DashLynx
AC help!! 07 Mustang V6 4.0
Old 05-25-2014, 01:42 PM
csparks2007
csparks2007's Avatar
Cool AC help!! 07 Mustang V6 4.0
Ok, here goes...I have a 2007 For Mustang V6 4.0
The AC seeps out cold air but there is no force, same with heat. So far I have replaced the cabin air filter, checked fuses, replaced the blower motor resistor and tested the blower motor (which works).
I should also mention there is a clicking sound win I start the car (even if ac is off) and when switching modes. I have determined that to be the blend door actuator. I've located where the clicking is. However I am assuming the clicking and non-blowing are not related problems.
My next task was to replace the blower motor switch but have been unable to locate it.
Any help or suggestions will be much appreciated!!!!
csparks2007 is offline
Old 05-25-2014, 02:33 PM
AzPete
AzPete's Avatar
Check and see if the air flow is directed out of the defroster vents at the windshield. The clicking of the blend door indicates a bad actuator. When that fails, the ducting fails to the defrost position as set by Ford. I would solve the blend door issue and see if that fixes your air flow issue.
AzPete is offline
Old 05-29-2014, 02:11 PM
Derf00
Gentleman's Relish
Derf00's Avatar
It should not be clicking at all. The click is the stripped plastic teeth rubbing against each other in the actuator. Yes they would be related because if the doors aren't moving, the air won't go anywhere.
Derf00 is offline
Old 05-29-2014, 03:31 PM
Steve@Tasca
Former Sponsor
Steve@Tasca's Avatar
Does it sound like it's trying to blow harder/speed up the fan when you turn the fan speed switch up or does the sound stay the same?
Steve@Tasca is offline
Old 06-03-2014, 06:47 PM
csparks2007
I replaced the clicking actuator. Still no ac
Old 06-03-2014, 06:49 PM
csparks2007
The sound doesn't change at all. If I hadn't tested the blower motor I would swear that is the problem.
Old 06-04-2014, 07:37 AM
csparks2007
Ok, got the climate control blower relay replaced....again, nothing!!!!
Old 06-04-2014, 07:56 AM
dawson1112
dawson1112's Avatar
Why dont you just replace the blower moter? How did you test it?
dawson1112 is offline
Old 06-04-2014, 09:18 AM
csparks2007
I wired it to my battery to assure it spins, the only way I knew to test it since auto part stores don't test blower motors. I haven't replaced it yet bc it's a $100 part lol. Looks like I'll replace it anyways!
Old 06-04-2014, 09:36 AM
Derf00
Gentleman's Relish
Derf00's Avatar
Ok, so you visually inspected the plastic blower wheel? If you did and it wasn't cracked or free spinning on the shaft, I'm at a loss.
The motor should change speed as the dash switch tells it.
Have you replaced the dash switch?
Derf00 is offline
Quick Reply: AC help!! 07 Mustang V6 4.0
