Common Ford IAC# F50Y-9F715A, F5TZ-9F715B and, F50Z-9F715AB operation?
Old 07-26-2014, 07:12 AM
knownenemy
knownenemy's Avatar
Default Common Ford IAC# F50Y-9F715A, F5TZ-9F715B and, F50Z-9F715AB operation?
Hi all!
Posted this same thread in the new member section, and it was suggested I post it here.
"First and foremost,
I am not a Mustang owner.
I joined your forum for information, because I may be using a Ford part in a custom design.
That part would be an IAC valve used on several Ford engines in the 1990s.
IAC# F50Y-9F715A, F5TZ-9F715B or, F50Z-9F715AB
It has been used on 4, 6, and 8 cylinder engines, and I need to know how it operates, or basically,
What type of IAC it is?
- Step Motor
- Duty control rotary solenoid
- Duty control, Air controlled valve
- On/Off vacuum switching valve
It's most likely a step motor, as this was most common in those days.
However, since I would be using this for a custom intake set-up which utilizes a Ford T/B,
this information is quite important for my CAL.
Thank you, in advance for any help.
Have a great day!
Donnie"
knownenemy is offline
Old 08-29-2014, 07:50 AM
knownenemy
knownenemy's Avatar
Bump
Would still like to get the info on the IAC, if anyone can help.
Thanks.
Diode Dynamics
28
05-26-2022 12:02 PM
drfister
05-03-2018 10:38 PM
dubarado
12-23-2015 01:16 PM
Spiral534
10-06-2015 04:31 PM
Hogquad
08-23-2015 05:26 AM
Quick Reply: Common Ford IAC# F50Y-9F715A, F5TZ-9F715B and, F50Z-9F715AB operation?
