Sponsored by:
Sponsored by: DashLynx
Fuel cap
Old 05-02-2015, 03:37 PM
surfergirltg
surfergirltg's Avatar
Default Fuel cap
5 days ago I put a half a tank of gas in my 2005 Mustang.Today when I was driving the check fuel cap light came on.I checked to see if the cap was on tight enough and took it off and put it back on but the check engine light came back on.Anyone know what else could be causing the problem ? Thanks.
surfergirltg is offline
Old 05-04-2015, 10:10 PM
cruisin5268d
cruisin5268d's Avatar
My money is on a bad seal or a leak somewhere. Next guess would be a sensor.
cruisin5268d is offline
Old 05-05-2015, 03:17 PM
surfergirltg
Smile
How would I check to see if there is a bad seal and if it is a sensor is it an easy fix ? Thanks
Old 05-05-2015, 09:07 PM
jz78817
jz78817's Avatar
easiest way is to hook up a scan tool and see what codes are present. if they're "evap" codes (evaporative emissions faults) then it's likely related to the gas cap or gas tank filler system.
jz78817 is offline
Old 05-05-2015, 11:50 PM
jwog666
jwog666's Avatar
the check fuel cap light will set an evap code, this only means that the leak is large enough to be a loose gas cap(it could be anything else that leaks as much), the only real way to see if there is a problem is to command the vent valve closed with a scan tool, and use a smoke machine to pressurize the evap system, this will tell you if it leaks, and if it does where it leaks. anything else is just a guess
jwog666 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
Dathan
10-05-2015 05:52 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: Fuel cap
