Front O2 sensor replacement on 2001 GT
Curious how difficult these are to replace. When I replaced the rear O2s, I was looking for the fronts and while I found the actual sensor I didn't find where the wiring plugs in. It seems like the connector isn't easily accessible and I'm wondering if I should let a mechanic do it or maybe if I should approach the sensor plug in from the engine bay vs. under the car?
Any advice?
Any advice?
depends on if my hand/arm will fit or not, i dont remember off hand, its been a while since i changed mine. all you can do is roll up your sleeves and try it, you will see which way works the best. most are easier from the bottom
jwog666
12-27-2021 08:09 PM
TfcCDR
09-14-2015 12:08 PM
