Sponsored by:
Sponsored by: DashLynx
Help brake light works intermittenly
Old 08-29-2015, 01:42 PM
MustangGirl98
MustangGirl98's Avatar
Default Help brake light works intermittenly
I have a 1998 Mustang Convertible gt and the passenger brake light works intermittently I have cked every wire.The only time my brake light works if I put the right directional on first but then when the next time I step on the brake it doesn't work again, then it will work sometimes on it own. I have to remind myself everytime I step on the brake to but the directional on quick......grrrrr. This is driving my absolutely crazy! I had a few ppl look at it and they are baffled as well. parking lights and directional work. I also cleaned out harness. Help it's driving me crazy and I don't want to get pulled over again.
MustangGirl98 is offline
Old 08-29-2015, 09:14 PM
Urambo Tauro
Urambo Tauro's Avatar
Have you checked the bulb? Sometimes the filament will go funny before it fails altogether.
Urambo Tauro is offline
Old 08-29-2015, 10:10 PM
MustangGirl98
yes, I have also change all the bulbs.
Old 08-30-2015, 09:51 AM
Chromeshadow
Chromeshadow's Avatar
Have you checked all of the grounds? You might try adding a ground wire to the the light bulb socket and run it to a known good ground.( you can clip or hold a wire to the socket ground) You should be able to put the plus side of a voltmeter on the ground part of the socket and the minus to a good ground, if you see more that about .5 V you have a poor ground.
Chromeshadow is offline
Old 07-23-2016, 07:24 PM
MustangGirl98
Default Update
I finally found out what it was.... it was the multifunctional directional switch. It was an easy fix. I hope this can help someone who has the same problem.
Old 07-23-2016, 08:20 PM
Chromeshadow
Glad to hear that. Was it hard to replace?
Old 07-24-2016, 07:34 AM
MustangGirl98
Default Easy peasy
Not at all just took the column off and the switch has two screws and pull the two plugs out and plug in the new one screw back in pit column back on oh and I forgot about the under dash plate needs to come off to but all easy peasy.😀
Originally Posted by Chromeshadow;85534
40
Old 07-27-2016, 12:29 AM
SyNdicateZ
SyNdicateZ's Avatar
Where is the switch located?
SyNdicateZ is offline
Old 08-01-2016, 07:39 PM
MustangGirl98
Default It's located in the steering column
It's in the steering column
Old 08-01-2016, 08:38 PM
Z28KLR
Z28KLR's Avatar
Multi-function switch is the turn signal lever. Since it also has controls for the wiper, hence the "multi-function" in the name.
Z28KLR is offline
Quick Reply: Help brake light works intermittenly
